Bongo | -- 04-07-2015 @ 7:14 AM |
Whats the best and easiest way to install the back windows(those above the trunk) on a 1939 ford 2dr sedan deluxe?
TomO | -- 04-07-2015 @ 9:51 AM |
The best way is to install the rubber seal on the glass and insert a string in the grove for the body. Have someone put pressure on the glass from the inside, while you work the string to pull the seal trough the opening. Car wash soap can help lube the seal so it slides easier. Make sure that you have the correct seals. I received sedan seals for my coupe and had to cut them to install them the night before leaving for a National meet. Here is a link to the procedure. http://www.vanpeltsales.com/FH_web/flathead_drawings_body.htm Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8391 |
