rdt52flthd | -- 02-21-2010 @ 1:07 PM |
Is there any way to restore the ability of the door (tudor) to stay open at full swing. There seems to be a detente at full open position which slides between a pair of jaws. Everything is worn and the jaws appear to be unadjustable. C & G sells check arms for some models, but not 52s. Any help on this? Thanks
supereal | -- 02-22-2010 @ 10:31 AM |
Be sure you have the "door check" rubber bumpers that slide over the arms. If there is a detent, chances are that without the bumper, you are going past it. C&G sells the arm and bumper as B-702828-S for $7.
rdt52flthd | -- 02-23-2010 @ 8:09 AM |
Thanks for the comback. I looked at the one in C & G, but that number lists it for the pickup or a Mercury. Is it the same part?
supereal | -- 02-23-2010 @ 8:23 AM |
If you look carefully, that part covers a wide range of models and years from '39 thru the '52 PU.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=838 |
