Hal | -- 03-19-2015 @ 9:44 AM |
Guys I have 36 ford fuel gage with 3 terminals. The two top terminals have a small board between them with wires around it?. What is this ? Then theres the bottom ter- minal. Can anyone tell me how there wired? Which wire goes to the sending unit. Where the hot wire's go. etc. I really need help. Thanks a million Hal
Don Rogers | -- 03-19-2015 @ 12:27 PM |
Hal, The enclosed picture should help.
Hal | -- 03-19-2015 @ 1:23 PM |
Hey Don, Thanks for your answer, but your gage does'nt resembel mine. Mine is single only for fuel,no oil. Thanks for your info. I really appreciated it. Thank's again. Hal
Don Rogers | -- 03-19-2015 @ 3:05 PM |
Hal, Can you take a picture of the gauge..front and back??
Hal | -- 03-20-2015 @ 9:18 AM |
Thanks DON, I haven't got the know to do this, but if you hold on a bit, Ill have my son do this this evening. Hang tight. Hal
Hal | -- 03-20-2015 @ 2:54 PM |
Don, Here's the pictures of my '36 Ford fuel guage.
Hal | -- 03-20-2015 @ 2:56 PM |
Don, Here's the back
Hal | -- 03-20-2015 @ 2:58 PM |
One more of the back
Don Rogers | -- 03-20-2015 @ 3:29 PM |
It looks like the gauge has been adapted for 12volts? A standard 6 volt gauge only has 2 terminals. Are you running a 6 or 12 volt system?
Don Rogers | -- 03-20-2015 @ 5:05 PM |
Hal | -- 03-21-2015 @ 8:49 AM |
Hi DON, It's a 12 v. When I bought this car, it was a 6 v and the gauge wasn't working. I changed the car to a 12 v. Since it wasnt working, they must have asked me if it was 6 or 12v. I ordered a i2 v. In any case the gauge works. I checked it off the car Thanks again hal
Hal | -- 03-21-2015 @ 9:12 AM |
Hi Don It's a 12v. When I bought the car it was a 6v.,and the guage wasn't working. I changed it to a 12v. I ordered a 12v not knowing there was a differance,anyway I in- stalled it and it still did'nt work so I ordered a sending unit, and it worked.I discovered lately it didnt work,but the guage works. I took it off the car, and it works.
TomO | -- 03-22-2015 @ 11:40 AM |
Hal, I am confused, do you still need assistance in connecting the gauge? Tom
Hal | -- 03-22-2015 @ 6:30 PM |
Ya I do. The wire going to sending unit, is it a hot wire? If I put a hot wire from the + side of the battery to the upper left terminal on the guage the bottom terminal has 12v, and if I attach a line from the - side of the battery to the bottom terminal ( on the guage ), the needle moves up. Now I have to figure the wiring. What do you thing? how do I make the needle go down besides removing the - wire? Hal
TomO | -- 03-23-2015 @ 8:46 AM |
I cant tell how the voltage reducer is wired because it is under the tape, but here is my guess. The terminal with no wire should go to the sending unit, the bottom terminal should go to the hot lead. You may have 12 volts at the top terminal until the sending unit is connected. Tom
Hal | -- 03-24-2015 @ 9:06 AM |
Hey don, I think I'll hang it up, I also think the sending unit is shot. I think I'llwork on something else. I want to thank you for all your help. Take care Thanks again....Hal
Don Rogers | -- 03-24-2015 @ 12:16 PM |
Hal,Sorry to hear that the sending unit is shot. It may be a good idea to hang it up for a while or until you get another sending unit. Regards, Don
TomO | -- 03-25-2015 @ 8:39 AM |
Hal, the sending unit provides the ground for the circuit. Your gauge seems to be working OK. If you have an original sending unit, it can be repaired. Here is a post that shows how to check out the sending unit and gauge. https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8150&keywords=gauge Tom
Hal | -- 03-26-2015 @ 8:20 AM |
hi don, will be writing to you later. Hal
Hal | -- 03-31-2015 @ 9:38 AM |
TomO This is hal. I recieved my new sending unit a couple of days ago. I wired it the way you told me, and it works. I'm going to reinstall everything and see if everything still works. Will it be ok if I install a new wire (12-14)gauge from the fuel gauge to the sending unit? Hal
TomO | -- 04-01-2015 @ 9:36 AM |
Hal, it is your car,so make any changes that you would like to. The original should work if it is not broken or has lost its insulation. a 14 gauge wire should work fine. Tom
Hal | -- 04-02-2015 @ 9:47 AM |
Hi Tom Thanks a million for everything you & Don helped me out with. It's guys like that are really app-reciated, by guys like me We'll I guess I'll go put everything to gether- so here goes! Thank's again Hal
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8330 |
