Can38 | -- 02-17-2010 @ 3:57 PM |
Hi I need some info for my 38 del cpe Will 39 standard front fenders interchange. And will I be able to use 40 sedan rear fenders on the 38 del cpe.
37RAGTOPMAN | -- 02-17-2010 @ 4:37 PM |
37-38 COUPE and CABRIOLET are similar ,except for the tail light mounting hole, the 40 fenders mount entirely different, I doubt the front fenders will work,also, you can always use fiberglass fenders, till you find orginals. the rear 38 coupe cabriolet fenders are scarce,
Stroker | -- 02-18-2010 @ 11:43 AM |
38 Deluxe and 39 Standard front fenders will interchange. The only difference is in the inner fender panel, not the fender. The inner fender panel on a 39 Standard has an opening for the hydraulic brake line.
Can38 | -- 02-18-2010 @ 6:14 PM |
Well thanks for that info now I have my other front fender
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=823 |
