tphiel | -- 02-07-2015 @ 12:28 PM |
Is there a lube / sealant used on the 59ab water pump gasket?
kubes40 | -- 02-07-2015 @ 3:50 PM |
A thin sealant is a good idea applied to both sides of the gasket. Be certain to avoid covering the oil passage hole.
cliftford | -- 02-07-2015 @ 8:59 PM |
If both water pump and block surfaces are perfectly clean and flat, no sealer is needed, I always coat the gasket with a thin film of grease, plus a little in the bolt holes just to be safe. I do the same on thermostat housings. It makes them easier to remove in the future without a lot of cleaning and scr*ping. I learned this trick from an old timer back in the 50s.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8186 |
