robertiford | -- 02-05-2015 @ 9:51 AM |
Please see my previous post. I have attached a picture of the front mounting (near the base of the firewall). Is this correct? The problem is, the front seems to be mounted too far away from the frame, because there is a gap between the body and the rubber pad on the sides under the front and middle posts. Help!
flathead48 | -- 02-05-2015 @ 1:25 PM |
Robertiford, that hole next to the from mount that you have a bolt in is for bolting the lower end of the inter fender. The body does not touch the side of the frame. Hope this helps.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8178 |
