Mr_Corvair | -- 02-01-2015 @ 7:58 PM |
My 46 front spring cover needs to be removed so I can take the spring apart and clean, bevel, lube and reassemble.Is it possible to remove the spring cover without destroying it and replace it afterwards when reassembling the spring?
flathead48 | -- 02-03-2015 @ 3:59 AM |
When I did mine I took the leaves out one at a time and put it back together the same way, the covers are stapled and I think would be very difficult to get back together properly. Good luck, Rick
kubes40 | -- 02-03-2015 @ 8:08 AM |
It can be done but you will need to flatten the spring out completely to do so. This requires a special fixture.
avrotom | -- 02-15-2015 @ 10:17 AM |
If you look in the KRW tool catalogue there is a picture of the tools required to correctly do the job, also the tools look easy to copy.
avrotom | -- 02-15-2015 @ 12:44 PM |
Mr Corvair, I have attached a scan of the tool page, hope that helps
avrotom | -- 02-15-2015 @ 12:47 PM |
Sorry, its upside down. finger problems.
Mr_Corvair | -- 02-16-2015 @ 6:27 AM |
Thank you very much for the replies. I think I'll just look for another spring.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8165 |
