tubetype | -- 01-23-2015 @ 8:09 AM |
Is the vent window housing assy mounted on front doors adjustable? BUD
TomO | -- 01-24-2015 @ 8:53 AM |
The 49-51 Shop manual does not discuss adjustments on the Victoria, but I believe that the convertible adjustment for the vent window would be the same on the Victoria. Tom
tubetype | -- 01-24-2015 @ 1:45 PM |
thanks Tom. I have the book from v8club. and it states the only difference between the conv and victoria that the Vic has had a metal top welded on. We'll see. In the next month or so I will remove he door panels and have a look BUD
trjford8 | -- 01-25-2015 @ 8:43 AM |
As I recall the vent windows have a plate(cam) on the bottom that allows the window to stop at a certain point when opened. This plate can be misplaced on the assembly if someone has worked on the window for come reason.This can keep the window from opening or closing properly. This message was edited by trjford8 on 1-25-15 @ 8:43 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8128 |
