lautens | -- 12-31-2014 @ 3:30 PM |
just installed a 1938, 60 hp and when idling i'm hearing an intermittent squeaking/squawking sound. is it possible that the fuel pump is acting up. perhaps a dry diaphragm!
1932BB | -- 12-31-2014 @ 5:58 PM |
Check to see if the rubbing blocks on the points are lubricated. It is surprising how much noise they can make if dry.
lautens | -- 12-31-2014 @ 6:04 PM |
when I listen, sounds like it's coming from the rear. in the fuel pump area.
nelsb01 | -- 01-01-2015 @ 5:58 AM |
When I had a 1937 60hp it was always the fan belt. Solved that with a light spray of WD-40.
TomO | -- 01-01-2015 @ 8:14 AM |
I have never heard a squeak coming from the fuel pump. but I always pack the operating arm with a light grease. Use a screwdriver as a stethoscope to isolate the noise. Tom
keith oh | -- 01-01-2015 @ 12:05 PM |
The old saying about squeaks and rattles in old fords was,'be glad you have two parts close enough together to squeak and rattle".
trjford8 | -- 01-01-2015 @ 1:07 PM |
Keith , I'll add to that with the old saying "if it ain't leakin' oil it's out of oil"
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8064 |
