geoford41 | -- 12-22-2014 @ 9:44 AM |
Need help in removing the door garnish moldings oin a 1939 deluxe coupe. The moldings are held on with clips instead of screws and I have never removed these moldings If any one has detailed instrction I would appreciate it. there was a link to vanpelts website on 40-46 cars but they use screws to hold on the moldings thanks I have attached the passenger doorphoto
kubes40 | -- 12-22-2014 @ 3:45 PM |
These are fairly simple to remove. I suggest pulling them downward a bit as you pull them out - from the top. It'll take a little force but once you have removed one, you'll no longer be apprehensive to tackle this job. Mike "Kube" Kubarth
geoford41 | -- 12-22-2014 @ 7:59 PM |
I'll give it a try tomorrow, I just order new clips from drake today in anticipation of "mishaps" and replacing a molding on the drivers door thanks George
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8034 |
