Fordfan1 | -- 12-15-2014 @ 1:33 PM |
I have a flywheel that came off a 52 engine will it work on my pre 48 engine, what are the differences if any-?
deuce_roadster | -- 12-15-2014 @ 3:44 PM |
No, the flywheels are different. If you set both flywheels on a 1" slug of metal ON THE FLYWHEEL CRANKSHAFT mating surface next to each other you could see the ring gear is in a different spot.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8009 |
