smokinjoe | -- 12-13-2014 @ 7:32 PM |
Hi Does anybody know the measurement of a 41 ford rear axle ? I need the measurement from wheel mounting surface to wheel mounting surface. The brake backing plate to backing plate isn't going to work for me , I measured one at 52" backing plate to plate. but am told that isn't accurate enough . I have a late model drivetrain right now (previous owner) but rear axle seems to be to wide. would like to find a smaller axle but would like to be as close as possible to the stock size so it will look right. Thanks Joe
trjford8 | -- 12-14-2014 @ 7:38 AM |
What is the width of the axle that is in there now, wheel flange to wheel flange? Do you have parallel leaf springs? Are you using wheel adapters?
41-42fordadvisor | -- 12-14-2014 @ 8:42 AM |
I hope this helps the rear tread for 1941 is 58.25". The rear tread for 1942-48 is 60". The rear spring length for 1941 is 48". The rear spring length for 1942-48 is 49.5". Fred Killian
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8002 |
