RPB43 | -- 12-06-2014 @ 12:04 PM |
How do you get the ignition cylinder out of the ignition switch housing on a 1949 ford car?
Big Red 51 | -- 12-06-2014 @ 12:14 PM |
RP, There should be an oblong hole on the key cylinder shaft near the switch housing. With a small screwdriver or punch, just press the button down and pull the key cylinder out with the key. Don
RPB43 | -- 12-06-2014 @ 1:52 PM |
I must have a after market switch housing The cylinder just doesn't want to come out.Thanks for the info. RPB
DD931 | -- 12-06-2014 @ 7:55 PM |
Read the discussion on the same subject in the Truck section. Everything you need to know.
RPB43 | -- 12-08-2014 @ 1:04 PM |
Thanks for your helpful information on the ignition switch.It was a bear but I finally got it out.The tumblers were coming apart and thats what made it so hard to get out.This one the switch key had to be in the run position to make the pin release.Replaced it with a Dennis Carpenter ignition cylinder and everything works perfect.Thanks Again RPB
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7980 |
