lautens | -- 11-27-2014 @ 2:20 PM |
just wondering where the best place to winch up to remove engine. carb mtg., spark plug hole/manifold or somewhere else?
lautens | -- 11-27-2014 @ 2:53 PM |
60hp
ken ct. | -- 11-27-2014 @ 7:03 PM |
Never by the carb mount. Use the tapped holes in the block for the intake manifold. Use 2 mallible iron eye bolts 1 in front and 1 in rear.ken ct.
trjford8 | -- 11-28-2014 @ 10:39 AM |
I bought a scr*p of steel plate that was the width of the intake manifold and about 16" long. With the intake remove I used it as a guide to mark holes in the plate. I used 8 holes (4 per side) and drilled it the so the bolts would pass through and tighten the plate to the intake surface of the motor. I also drilled the center of the plate in two places (about 3 inches from each end)to accept large iron eye bolts to attach the chain from the hoist. Using the plate spreads the weight so you are not using just a couple of bolts to lift the engine.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7955 |
