larryb346 | -- 11-27-2014 @ 1:36 PM |
I found a NOS trunk handle for my 39 coupe. I need to remove my lock and install it in the new handle. I can see a "pin" sticking up holding the lock in place. I have tried turning the lock with the key. I though there would be a place where the lock would turn and the pin drop into a hole when depressed and it remove. Thus far no luck. If I am correct, in approx what position does the key need to be in for the release pin to drop. Thanks Larry
40cpe | -- 11-27-2014 @ 6:40 PM |
I have little experience with actually removing the cylinder, but I've read that you turn the key 1/4 turn, press pin and pull lock out. Probably easier said than done.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7953 |
