dansford | -- 11-21-2014 @ 6:21 AM |
The 36 Ford Bob Drake repro. steering wheel was successfully repaired with 2 coats of JB Weld it bonded the stainless spokes with the diecast hub very well I had my 135 pound granddauhter stand on the wheel and there was no movement at all. dansford
Jim | -- 11-21-2014 @ 1:55 PM |
I tried the JB weld, but it popped out. I think the failure was due to not having a larger amount of hub material around the stainless spokes. With a Dremel tool, I am going to enlarge the area a bit more, then drill holes into the zinc to better hold the JB Weld. In an earlier post, I asked for suggestions for how to fix the banjo wheel and was encouraged to contact Lauren Matley, a V8 member who has restored these wheels in the past. Unfortunately he no longer repairs wheels, but spent a lot of time giving me suggestions. In addition to JB Weld, he recommended a product called PC 13, found at ACE Hardware stores.
dansford | -- 11-21-2014 @ 3:03 PM |
Hi Jim, I did a search on PC 13 and came up empty I wanted to read up on it. dansford
trjford8 | -- 11-23-2014 @ 8:06 AM |
I think it is PC-7. Go to; www.pcepoxy.com
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7936 |
