TonyM | -- 11-15-2014 @ 9:16 PM |
Is this a Ford Equipment Tire Air Pump? Maybe #48-17052A-2? . . . 78-73B
TonyM | -- 11-15-2014 @ 9:17 PM |
TonyM | -- 11-15-2014 @ 9:18 PM |
TonyM | -- 11-15-2014 @ 9:20 PM |
TonyM | -- 11-15-2014 @ 9:21 PM |
40 Coupe | -- 11-16-2014 @ 4:06 AM |
It appears to be. I believe there may be two slightly different pumps, the other has a different cap where the shaft exits the body. You may want to contact Lin Stacey for his expertise.
Don Rogers | -- 11-16-2014 @ 7:54 AM |
Tony, It appears from the photos that you have a 48-17052-A1 tire pump manufactured by Michigan Steel Tube. The tube cap where the tire pump plunger comes out of the tube is different than the Noblitt Sparks design (48-17052-A2)
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7922 |
