39 Ken | -- 11-09-2014 @ 4:40 AM |
I've seen a number of references that these senders can be repaired or rebuilt. Looking for information as to how to rebuild or who in the flathead world rebuilds/repairs them. Ken
TomO | -- 11-09-2014 @ 6:49 AM |
Baxter Ford services the fuel sender. A quick check to see if you can clean the contacts and get it working is to connect an ohm meter between the center contact and the flange. Move the arm up and down slowly while observing the meter. If the meter fluctuates to 0 Ohms while doing this, you can probably just pry the top off and clean the contacts with Tuner cleaner. Be very careful around the wires as they will break easily and the unit willl have to be sent out for repair. Tom This message was edited by TomO on 11-9-14 @ 6:50 AM
TomO | -- 11-09-2014 @ 6:52 AM |
here is a photo of the inside of the sending unit. Tom
Drbrown | -- 11-09-2014 @ 7:41 PM |
TomO .... Nice response. What else do you have in your bag of tricks ? Thanks
39 Ken | -- 11-09-2014 @ 11:59 PM |
Thanks Tom. I'll check it out. Ken
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7901 |
