TPAYR | -- 10-28-2014 @ 1:54 PM |
A question for the engine experts.... I`m going to tear down my 1933 engine this winter so I`ll be needing to buy a full v8 engine gasket set... they seem to be sold either in steel or copper (head gaskets)... which is the best and where is a good source... comments please and Thanks in advance. Cheers
TomO | -- 10-29-2014 @ 7:17 AM |
There is little difference in performance between a quality steel head gasket and a quality copper head gasket. I prefer the steel head gasket as there is less chance of corrosion due to dissimilar metals. I also prefer the FelPro gaskets. I don't think that FelPro makes the 21 stud gasket sets any more, so any set sold now would be a few years old. If you do order the FelPro set, inspect the paper and cork gaskets for signs of age deterioration. Dried out gaskets do not seal very well. Tom
TPAYR | -- 10-29-2014 @ 2:23 PM |
Thanks for the info Tom.... do you know of any sources?
shogun1940 | -- 10-29-2014 @ 8:31 PM |
you can soak cork gaskets in water if they have shrunk and are still solid
TomO | -- 10-30-2014 @ 7:27 AM |
Mac's catalog still has them listed and other suppliers may also have them. Tom
JM | -- 10-31-2014 @ 3:04 AM |
I would recommend getting your gasket set from Best Gasket Company. I have used their sets for the last several engine builds and they are very high quality gaskets. http://www.bestgasket.com/ John
3w2 | -- 10-31-2014 @ 5:53 PM |
Copper gaskets work well with cast iron heads, but are a disaster with aluminum heads because of electrolysis.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7864 |
