Hal | -- 09-25-2014 @ 8:59 AM |
Hey guys, Yesterday, I discovered three spark plugs on the left head (passengers side) are leaking little bubbles. I did'nt ck. the right.Can anyone tell me what the problem might be on my 36 ford? What do I have to do to fix the problem? Is there a Quick fix? I appreciate all the help you guys can give me. Thanks a Million Hal
Don Rogers | -- 09-25-2014 @ 11:09 AM |
Remove the plugs and check the spark plug and head openings for durt and corrosion. Replace the copper spark plug ring gaskets with new uncompressed ones.
supereal | -- 09-25-2014 @ 11:35 AM |
Are they leaking around the place where the plug screws into the head, or where the porcelain shank meets the base? If the bubbles are coolant, it is a good bet the head is damaged, and will have to come off for inspection. If you are lucky, it will be the head, and not a block crack allowing coolant into the three cylinders. Leakage into the cylinders can result in "hydrolock" which can destroy the engine if it is growing.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7762 |
