svmsr1044 | -- 09-23-2014 @ 3:06 PM |
Is it "normal" for a '40 91-99 Carburater to "leak down" or to have gas spill out from the base when the engine is turned off? Thanks, Steve2
cliftford | -- 09-23-2014 @ 4:09 PM |
No, its not normal. I'm guessing you have a leaking power valve and/or PV gasket.
svmsr1044 | -- 09-24-2014 @ 1:19 PM |
Additional info on my "leak down" carburator: The idle mixture screws have minimal effect in adjusting idle. Kenct, do you have any thoughts on this one? Thanks,Steve
cliftford | -- 09-24-2014 @ 3:57 PM |
That's a sure sign of the power valve or gasket leaking. At idle, the engine is drawing fuel through the power system instead of through the idle system.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7755 |
