Forgotten Ford | -- 08-28-2014 @ 7:12 AM |
Does anyone can help me to explain how to change the 1935 Ford Front Motor Mounts? I already have removed the nut, but I cannot take the screw out! I put a wrench and I can spin it, but it doesn't go down? What I'm doing wrong? regards Keeping crazy finish my Dad 35'Ford restoration!
TomO | -- 08-28-2014 @ 7:22 AM |
The screw will probably drop out the bottom when you raise the engine to replace the cushions. Make sure to distribute the weight on the oil pan with a wide flat board on your jack. Tom
VT/JeffH | -- 08-28-2014 @ 7:37 AM |
Hi, When raising the front of the engine be careful that the fan doesn't crunch the radiator. -VT/JeffH
trjford8 | -- 08-28-2014 @ 7:51 AM |
You may have to tap it out with a hammer. The old rubber may have "welded itself" to the shank of the bolt.
Forgotten Ford | -- 09-01-2014 @ 9:35 AM |
Very thanks folks for all advices and tips! Work done, and my flatie is running on new cushions! Keeping crazy finish my Dad 35'Ford restoration!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7672 |
