39topless | -- 08-21-2014 @ 11:30 AM |
Looking for some tech help for removing the old rubber from original running boards. Thank you
cliftford | -- 08-21-2014 @ 1:38 PM |
If its not too brittle, a heat gun and a gasket scr*per or putty knife will work pretty well.
39topless | -- 08-21-2014 @ 2:56 PM |
Sounds like a plan. I'll try it and report back. You notice your use of the word "scr*per" was found to be offensive? Shame on you!
trjford8 | -- 08-21-2014 @ 6:23 PM |
I've also used a small hand held torch. Work outside as the fumes are not nice.
39topless | -- 08-21-2014 @ 6:34 PM |
Sounds like it's going to be a lot of fun. Thanks for the tips.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7641 |
