John Lubinski | -- 08-18-2014 @ 10:04 AM |
I had to replace the upper steering bearing in the 46 when I pulled the old(bad) one out I noticed the bearing housing was still in the tube,about an inch down in the tube.It does not want to come out,can I just put the new bearing in this housing? Seems that this does hold the bearing in place.Thanks John lubinski
supereal | -- 08-18-2014 @ 10:25 AM |
John: That bearing is held in place by a rubber collar that rides on a bushing sleeve. You can see the assembly on page 52 of the C&G online catalog. Getting the old one out can take some patience, as they are usually stuck in the tube.
trjford8 | -- 08-18-2014 @ 6:50 PM |
You might try drilling a small hole in the housing sand then use a slide hammer(dent puller) to get it out.You can also drive it down further and then put the new bearing in the same location.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7628 |
