Esteban34 | -- 08-16-2014 @ 9:08 PM |
After shifting, and accelerating, my 34 Ford hiccups through the carb and may also backfire through the exhaust. Any ideas? I know of a small exhaust leak near the crossover pipe. Could this be a factor? Thanks in advance. adonde vas, estas alli Esteban
ken ct. | -- 08-16-2014 @ 10:32 PM |
Could be 1 or more sticky valves,try some MMO down the carb and some in the gas tank. Fix the exhaust leak first. Or carb needs a rebuild and dist needs checking. Could be a multitude of reasons ?? ken ct usa
supereal | -- 08-18-2014 @ 10:31 AM |
It is often caused by a vacuum leak caused by worn throttle shaft bushings and/or shaft. Backfiring is most often due to a vacuum leak in or around the carb.
Esteban34 | -- 08-23-2014 @ 8:50 PM |
Thanks, I'm working on the exhaust leak. I will check for vacuum leak, too. Distributor and carb are sorted, so can rule tem out. adonde vas, estas alli Esteban
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7625 |
