tip | -- 08-14-2014 @ 4:43 PM |
Hi It may take hardcore ford guys to answer my question or it might be a common occurrence. Can you develop "vapor lock" driving down the highway at 60 mph.
supereal | -- 08-14-2014 @ 8:03 PM |
See my comment under the earlier "fuel syarvation".
TomO | -- 08-15-2014 @ 6:22 AM |
The simple answer is probably not. If you are having problems at 60 mph, it is probably due to an incorrect float level setting, weak fuel pump, bad flex line or obstruction in the line from the tank or pickup in the tank. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7618 |
