pops35ford | -- 08-06-2014 @ 5:17 PM |
Hello, I could use some information on my 1935 ford 3 window, having problems with Hood fitting ? please help !!
JM | -- 08-09-2014 @ 9:11 AM |
You need to provide more details about your problem and maybe some pictures showing us what you have or are trying to put together. The complete and correct front end assembly is critical if all parts are to fit properly. John
pops35ford | -- 08-10-2014 @ 10:48 AM |
thanks John, I will try to put some pictures on here,the hood doesn't come down on the fenders far enough, the hood bumpers are showing, and the hood is not fitting the contour right on the grill, I'm thinking I have the wrong hood tops ? ... thanks fore responding.... ken
flatheadfan | -- 08-11-2014 @ 6:05 AM |
pops35ford- It is hard to get a truly perfect hood fit on a '35 Ford hood/grille. However, there is basically only one way to get alignment and that is with the two radiator rods. If you wish give me your direct email (PM if that is more convenient) and I will send you pictures of my '35 hood alignment. The car just turned 40K miles. Tom
JM | -- 08-11-2014 @ 8:07 AM |
Ken, I once had a complete front end sheetmetal allignment procedure for a '35 Ford. It was filed in my computer, but I am not sure how or where to find it now. Many things could affect the height of the hood. Two that I recall from a post on another website were: 1. Cushioning material under radiator support feet was too thick. 2. Recored radiator was incorrectly made higher than the original. John
pops35ford | -- 08-12-2014 @ 8:20 AM |
ok thank you, its not low enough on the fenders also, the hood is up like one inch .. thanks ... ken
pops35ford | -- 08-12-2014 @ 8:27 AM |
Hi Tom.... as you can see in the picture the hood is up about 1-inch from the fenders carcruisin@msn.com
flatheadfan | -- 08-12-2014 @ 11:36 AM |
This may sound flaky but, how much room do you have between the fan with a blade in the 12 o'clock position and the radiator? Tom
pops35ford | -- 08-13-2014 @ 6:30 PM |
not much I can just about put the fan on when the radiator is installed... but that's not the problem it needs to come down on the fender, thanks anyway... ken
Don Rogers | -- 08-14-2014 @ 5:44 AM |
Ken, How does the grille fit at the bottom with the fenders. Could you take some photos of the grille from top to bottom both with the hood closed and open? Don
TomO | -- 08-14-2014 @ 6:03 AM |
Pictures of how the hood fits the cowl would also be helpful. Tom
pops35ford | -- 08-14-2014 @ 5:40 PM |
pictures of the 35 hood thanks.. ken
pops35ford | -- 08-14-2014 @ 5:44 PM |
the fits the cowl ok .. thanks... ken
JM | -- 08-14-2014 @ 6:04 PM |
Ken, can't tell much from your pictures other than confirming that you do have too much gap. Also, most of the pictures seem to be the exact same shot. Maybe back away some with the camera, give it time to focus, and take some pictures of the complete hood showing where it meets the cowl and the grille. Also as Don asked a picture of how the grille is bolted in at front of fenders. Some pictures with the hood sides propped up on top of cowl so we can see how the radiator is mounted and also how the hood fastens to the top of the cowl. John This message was edited by JM on 8-14-14 @ 6:06 PM
pops35ford | -- 08-18-2014 @ 6:46 PM |
thanks John, I will take more pictures of the 35 but it will be at a later date, I need to put another motor and trans in it thanks for your help ... ken
Gabuick | -- 09-25-2020 @ 6:18 AM |
Did you ever solve your problem? I’m having the same problem on our 35 couple This message was edited by Gabuick on 9-25-20 @ 6:19 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7581 |
