ftda1941sd | -- 07-17-2014 @ 10:28 AM |
I am in need of some information on the ignition switch body and wiring for a '41 business coupe. I have the ignition switch body with the 3 posts and its the metal cover but nothing else. I know I need a "brush" but what else? How does it attach to the steering column? Also where was the circuit breaker/fuse/coil resistor pad typically mounted? My switch and circuit breaker were hanging out from under the dash when i got it. Pictures would be a great help. Thanks you. Bob A
TomO | -- 07-17-2014 @ 10:35 AM |
The ignition switch attaches to the back of the steering wheel lock. The tang of the operating lever fits in the slot and moves the brush. The circuit breaker mounts on the inside of the fire wall above the steering column. There should be two holes for the bolts. Tom
ftda1941sd | -- 07-18-2014 @ 6:59 AM |
Thanks Tom for the information. I think I got it figured out now. Bob
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7516 |
