etuftedal | -- 07-10-2014 @ 7:59 AM |
Hi, My fire department is rebuilding our first fire truck, a 1936 ford. I am having some problems identifying parts for the rear wheel hub, specifically the bearings and seals. The truck is a dually. I beleive the rear hub bearing is a Timken BB-1240. Does that sound correct. Also, trying to locate a new seal as the one seal was broken during removal. I have included pictures for reference. Thanks in advance for all of your help.
etuftedal | -- 07-10-2014 @ 8:01 AM |
here is the seal
etuftedal | -- 07-10-2014 @ 8:02 AM |
And the bearing
etuftedal | -- 07-10-2014 @ 8:03 AM |
The internal nut (has small nub on it)
And the external nut
Don Rogers | -- 07-10-2014 @ 1:09 PM |
Heres an exploded view of a 36 truck full floating rear end. The parts you have shown are BB part numbers and are shown on the left of the view. I hope this helps you.
etuftedal | -- 07-11-2014 @ 6:28 AM |
Don, That is perfect, exactly what I was looking for. Now that I know what they are called, one last questions. When I look up a new style seal "BB-4245", it does not appear that the washer "BB-1124" is going to install into it. When I took the hub off, it looks like the washer and the seal are one part. With the new seals, do i still need the washer. Is the washer "nested" in the retainer ring like my picture above or are they installed separately?
Don Rogers | -- 07-11-2014 @ 2:23 PM |
I believe that the seal is seperate from the washer and is sold as two seperate pieces.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7498 |
