murphy 1941 | -- 07-07-2014 @ 7:52 PM |
Does anyone have a schematic of what pieces goes into making the radio antenna? Plus , is the antenna allowed to touch other metal parts ? My antenna seems to be made up of various mixed pieces so I don't know what belongs and what doesn't. Thks john Early Super Deluxe 41 Coupe
TomO | -- 07-08-2014 @ 6:21 AM |
Dennis Carpenter makes an excellant replacement antenna for the 41 Ford. http://dennis-carpenter.com/radio-antenna-assembly/p/11A-18813/ The original Ford antenna should not touch any body parts or grounds. If you have the side-mount or cowl mount antenna, the shield of the cable must be grounded. Tom This message was edited by TomO on 7-8-14 @ 6:24 AM
murphy 1941 | -- 07-08-2014 @ 11:20 AM |
Tom , my antenna is on the roof centered Thks for iinfo John Early Super Deluxe 41 Coupe
40 Coupe | -- 07-10-2014 @ 4:13 AM |
I believe the 41 is nearly identical to the 40 in installation.
40 Coupe | -- 07-10-2014 @ 4:14 AM |
More
Lincoln | -- 07-12-2014 @ 3:41 PM |
Here is the front and back page from PHILCO's Radio Service Manual for the Schematic and Installation Instructions of your radio. I may have some antenna odds and ends lying around for these Philcos, if I knew what you needed. Lincoln
Lincoln | -- 07-12-2014 @ 3:44 PM |
OPPS! My post did not show the schmatic, so here it is. Lincoln.
murphy 1941 | -- 07-15-2014 @ 7:51 PM |
Thank you all once again john Early Super Deluxe 41 Coupe
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7491 |
