Grant | -- 06-26-2014 @ 6:26 AM |
What modern automatic transmission fluid should be used in our 1951 Fordomatic? Is Dexron Mercon okay?
linz | -- 06-27-2014 @ 2:01 PM |
Later fordomatics took Type A auto fluid.you would have to check if yours is the same. I know dexron mercon 111 is a replacement for Type A. Check your label for dexron mercon Bill
Big Red 51 | -- 06-28-2014 @ 1:27 AM |
Grant, NAPA sells the Type A fluid for Fordomatics. Don
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7455 |
