Hal | -- 06-16-2014 @ 8:27 AM |
hey gang, I need 2 water pumps for my 36 ford sedan. they both have to be left handed, one for the temp sending unit, and the other for my heater. I can only locate, sellers with one left and one right. The right one won't do me any good since it doesn't have the threaded extension. can you help me? Hal
4dFordSC | -- 06-16-2014 @ 9:04 AM |
Mac's has them for 32-36, p/n 32-16860-1: "V8, 85 HP, cast as left side for sending unit, but will work on right side or left, includes a small brass plug, for use when mounting it on the right side."
Hal | -- 06-16-2014 @ 11:49 AM |
thanks 4dford I appreciate your help. will give them a call. thanks again Hal
transbytip | -- 06-16-2014 @ 6:06 PM |
Hal have some very good used ones$25.00 each plus shipping Cliff,tipper52501@yahoo.com with reguards Cliff. Tipton
40 Coupe | -- 06-17-2014 @ 4:03 AM |
There are RH bodies with cast iron nipples for heater connections. The nipples come out of the RH side so there is no interference from the engine or belt. The pumps are fairly easy to rebuild yourself or Skip Haney can do it. The special RH bodies are not that easy to come by and are not reproduced.
36ford pick-up | -- 07-01-2014 @ 1:56 PM |
Hal I bought a pair of original pumps in Carlile,Pa. a few years ago still in the original box, for a 21 stud head. Decided not to use them,instead got a pair from Fryer, so I have 2 pair of 36 ford 221 w/pumps. Let me know if this would help. 36ford pick-up
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7426 |
