shackiraq | -- 06-14-2014 @ 3:14 PM |
What was the original equipment 6 volt, positive ground, battery make and model and cold cranking amps? What make and model 6v battery should I put in the vehicle today?
Don Rogers | -- 06-14-2014 @ 8:24 PM |
There were 3 possible batteries: 81A-10655-A
Don Rogers | -- 06-14-2014 @ 8:26 PM |
81A-10655-B
01A-10655-A
supereal | -- 06-16-2014 @ 4:08 PM |
Unless you plan to show your car, I'd switch to an Optima redtop six volt battery. They provide over 800 cold cranking amps, and hold a charge for months. My '47 sat from September to June, and cranked and started as if it was just run. They are a bit pricey, but well worth it.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7421 |
