mgbrewer | -- 06-13-2014 @ 10:47 AM |
The horns in my 40 Ford have stopped working. The horns were working fine. The connections appears to be ok should I suspect the relay? There doesn't seem to be a fuse anywhere. - Mike
c-gor | -- 06-13-2014 @ 12:20 PM |
Suggest the following in that order 1. Check the connectors that fit into the spring contacts on the Horn Relay 2. Make sure you have a good ground, suggest a star washer 3.Remove Horns, remove Horn Bells and carefully clean points with a fine file
39topless | -- 06-13-2014 @ 3:16 PM |
How about trying a by-pass of the relay with a hot lead directly to the horns to see if it is the relay/horn button etc., first. If horns work, then work back from there.
TomO | -- 06-16-2014 @ 9:24 AM |
It is very likely that the contacts in the horn relay are dirty or corroded. You can check for this 2 ways, use a 12 gauge jumper wire to connect one of the horns to the battery or use a volt meter to see if there is voltage supplied to the horns when the horn button is pressed. The horn button provides a ground connection to the horn relay and the relay picks to supply voltage to the horns. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7415 |
