j.grif | -- 06-07-2014 @ 8:30 PM |
will a 97 carb be ok on a rebuilt 59a flathead? Using a shop rebuilt 94 carb but cannot get it to run smoothly. The valves are a litle noisy and plan to open the engine and check clearances and maybe install a known good 97 carb. Engine Just overhauled and started a day ago. vacumn 16 and all cylinders read evenly around 75-80lbs. No experienc using the 94. Thanks
ken ct. | -- 06-07-2014 @ 10:36 PM |
Compression sounds a little low but cause could be rings have not seated yet,may go up with some driving miles on it. Yes a 97 will work just as well as a 94 on that engine NO problem. ken ct.
40 Coupe | -- 06-08-2014 @ 3:34 AM |
Change Carburetors, if you know you have a good 97 and see how it runs, especially at idle. The valve noise, low vacuum, can both be a sign of a bad Carb. take a look at the plugs and make sure they are not fouled with soot. Your 94 could have a bad power valve or the gasket for the power valve may be leaking.
j.grif | -- 06-08-2014 @ 11:24 AM |
Thanks guys,installed the 97 and the engine sounds much better
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7397 |
