MTLott | -- 02-03-2010 @ 10:03 AM |
When changing to a diaphragm clutch, do you use the stock T.O. bearing and hub? Or do you use a special bearing and hub? Many thanks for any help and advice.
supereal | -- 02-03-2010 @ 11:30 AM |
It depends on the manufacturer of the clutch. Usually the standard bearing and carrier are used unless otherwise specified with the pressure plate, as the carrier must be correct for the transmission used.
37RAGTOPMAN | -- 02-03-2010 @ 4:01 PM |
is that for racing the flathead, that diaphram clutch is usually on and off, if you want a good clutch, stick with the original, my 2 cents 37RAGTOPMAN
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=735 |
