rbone | -- 04-28-2014 @ 9:13 AM |
How does the square lock shaft on the door lock attach to the lock lever on the inside of the door?
David J | -- 04-28-2014 @ 10:16 AM |
Are you asking how this lever attaches ? Slotted oval head screw if you are .
rbone | -- 04-28-2014 @ 11:23 AM |
Yes. Does the screw go into the square shaft? Mine is not drilled or tapped.
David J | -- 04-28-2014 @ 11:49 AM |
Yes
rbone | -- 04-28-2014 @ 12:36 PM |
OK - I guess I will drill it and tap it. Do you know the screw size? I would guess a #4x40.
David J | -- 04-28-2014 @ 1:46 PM |
Only 33's and the 34 roadster here at home as we are still in winter mode and none of these have them . Cannot help with the screw size today - sorry .
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7269 |
