coup | -- 04-18-2014 @ 6:12 PM |
Can someone tell me how far a 221 32 - 34 block be bored. Also how far if it is to be sleeved. Thanks Neil
JM | -- 04-19-2014 @ 5:49 AM |
The flathead engine building gurus on Fordbarn tell us that + 0.060 is the limit on the early 221 engine blocks, prior to '37. No idea on sleeving. If you post this question on Fordbarn, someone will let you know. John
TomO | -- 04-19-2014 @ 7:59 AM |
I would not sleeve an early block to achieve a bore larger than .062 oversize. You will have overheating problems. Tom
David J | -- 04-19-2014 @ 11:52 AM |
I have a 33 and a 34 with .060 33-34 blocks in them and they work fine . This message was edited by David J on 4-19-14 @ 11:53 AM
supereal | -- 04-19-2014 @ 8:24 PM |
The overbore depends on the sleeve size outer diameter, the usual largest being .060. Any larger has to special ordered from a vendor such as Mahle. Same is true of pistons and rings. It is very difficult to' bore old engines as they more often than not will have a sand hole from a core shift when made. At our shop, we do lots of boring. We fill the water jacket with a special material prior to boring to support the cylinder walls so the finish will be possible with the hone.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7242 |
