t35 | -- 02-01-2010 @ 9:05 AM |
my oil pressure sender does not have any numbers on the brass. how can i tell if its 50 or 80 lb.?
4dFordSC | -- 02-01-2010 @ 9:16 AM |
It is my understanding that sending units were not marked until Ford started using 80 lb. oil pumps, thus making it necessary to distinguish the sending units. As a result, 50 lb. units can be marked with a "50" or have no markings at all, whereas the 80 lb. units are always marked. I'm sure others will chime in to confirm or debunk this assertion.
ford38v8 | -- 02-01-2010 @ 6:45 PM |
You got the straight scoop on that one. Alan
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=723 |
