ramartin | -- 03-22-2014 @ 9:10 PM |
1936 ford rear axle/hub castle but size and thread?
CharlieStephens | -- 03-22-2014 @ 10:28 PM |
These are something you can't pick up at Home Depot or the local hardware store. These are a special extremely hard nut and I would only trust someone like Roy Nacewicz Parts, (313) 383-3673, fordbolts.com. When you buy from Roy or any other reputable supplier you don't need to give them the size and thread. Charlie Stephens This message was edited by CharlieStephens on 3-22-14 @ 11:02 PM
34billct | -- 03-26-2014 @ 6:25 PM |
And the answer is 5/8-18
CharlieStephens | -- 03-26-2014 @ 6:55 PM |
Sometimes a little knowledge is dangerous. I agree it is 5/8 -18 but what about thread quality and nut hardness? The Green Bible says it should be 356074-S. When you go to the section on fasteners the closest you can find is 356074-S18 which is what I assume is intended. It is described as 5/8-18 (23/32 x 1 1/4") Special hex. nut. Charlie Stephens
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7149 |
