flathead48 | -- 03-17-2014 @ 5:07 PM |
There is a small U shaped bracket that goes where the hood support arm and hinge the bracket is about inch & a quarter wide and about I inch & one half long. The problem is the bracket has 5/16 holes same as the hinge but the support arm has a 3/8 hole which leads me to believe it uses a shoulder bolt there. I have a picture but can't figure out how to post it. If anyone has seen this hooked upi I would appreciate any input. Thanks, Rick
kubes40 | -- 03-17-2014 @ 5:37 PM |
year? model?
Old Henry | -- 03-17-2014 @ 6:02 PM |
Is this what you're talking about? (Attached picture) If so, I believe this is the shoulder bolt: http://cgfordparts.com/ufolder/cgcat.php?searchtype=Search&x=x&year_choice=47&searchtextdesc=hood+bolt&searchnumber=48-6756 This message was edited by Old Henry on 3-17-14 @ 6:05 PM
flathead48 | -- 03-17-2014 @ 7:00 PM |
Right on Old Henry, problem is both sides of the bracket are 5/16 hole and support is larger for shoulder ?
flathead48 | -- 03-17-2014 @ 7:04 PM |
48 passenger
Old Henry | -- 03-17-2014 @ 8:37 PM |
I just took my bolt out to see what I have. It's a 5/16" carriage bolt (no shoulder) and the hole in my knee brace is 5/16" the same as the hole in the hinge and the U shaped piece. Nothing on mine is 3/8". Don't know what to tell ya. Sorry. This message was edited by Old Henry on 3-17-14 @ 9:02 PM
Old Henry | -- 03-17-2014 @ 9:00 PM |
Looking at this more I see that the hole in the top end of my knee brace is 3/8" for a shoulder bolt there (no U bracket). I wonder if you have your brace upside down?? It should have the spring at the bottom as shown in my picture.
40 Coupe | -- 03-18-2014 @ 4:20 AM |
Take a look in the green book p.370 shows a diagram of the hood and associated hardware. The U-bracket 11A-16779 is used 41-48 (see p. 621) go down the page and there is listed the hardware with Ford P/N in the back of the book is a detailed description of the hardware sizes shoulders heads etc. see if you can find what you need there. This message was edited by 40 Coupe on 3-18-14 @ 4:21 AM
flathead48 | -- 03-18-2014 @ 5:44 AM |
Thanks guys for the assistance, both ends of my knee brace are 3/8 holes as the reproductions I looked at, will check the green book, thanks , it's great to be involved with a bunch of guys that go out of their way to be helpful . Happy Motoring
Old Henry | -- 03-18-2014 @ 7:39 AM |
Just my opinion, but I don't think any harm would be done to install your knee brace with the 3/8" hole at the bottom with the 5/16" bolt going through it, the hinge hole, and the two U strip holes. I actually don't have all of the right shoulder bolts on mine and it all works just fine. And with that U strip hiding the holes, no one but you would know it's not exactly right. More of my philosophy of having fun without perfection here: http://www.fordbarn.com/forum/showthread.php?t=133565 Just have fun! (The Prime Directive)
supereal | -- 03-18-2014 @ 12:05 PM |
The correct bolt is a 1/4" X 28, with a 3/8 shoulder. The clip goes over the junction of the firewall bracket lowest hole and the bottom link of the hood support. C&G lists them as part # 3110. Lots of those brackets were drilled out to 3/8" when the original bolts were lost. There should also be a wavy washer between the link and the bracket to allow free movement. Many connectors in the hood support have holes in the heads for a safety wire that prevent them from working loose because they can't be fully tightened, or the links will be locked. When we find a hood that won't close at the firewall, almost always it is because the wrong bolts were used.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7129 |
