Topic: 6v temp gauge sending unit ?
Grant    -- 03-12-2014 @ 11:01 AM
  Does anyone know of a six volt sending unit that could be installed on the left water pump of a 1936 Ford to operate a six volt StewartWarner-type aftermarket temperature gauge ?
I have been able to locate only 12 volt senders and gauges so far.
As a further problem, the threaded portion of the available sending units is much larger than the threaded hole in the top of the 1936 left water pump.
Thoughts? Comments? Recommendations?
supereal    -- 03-12-2014 @ 5:16 PM
  You might consider an aftermarket bulb type temp gauge. The bulb can be installed in a hose, or into the radiator top tank by soldering in a fitting for the bulb. Finding six volt anything today is rare.
supereal    -- 03-12-2014 @ 5:17 PM
Grant    -- 03-15-2014 @ 6:55 AM
  What about using a temperature gauge which has an old-style capillary tube as a sending unit, rather than an electrical one?
As long as the threaded end of it could be adapted to screw into the left water pump housing, would this not be a workable solution?
The '36 in question is a Touring A vehicle, so having vintage aftermarket under-dash Stewart Warner gauges is not an issue.
trjford8    -- 03-15-2014 @ 7:49 AM
  Grant, that would certainly work, but you need to find the correct adapter and a gauge with a small enough bulb on the end of the tube to go into the adapter.
TomO    -- 03-15-2014 @ 8:02 AM
  You could also try to convert this Model A gauge and sender to your car.
http://www.snydersantiqueauto.com/1920
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7117
