4ford | -- 03-11-2014 @ 3:03 PM |
can someone that has a 1941 ford coupe take a measurment from the lower part of the fender buy the cowl up to the seam kind of in the center.. what iam doing is replacing the bottom corner and need a good measurment. thanks
joe b | -- 03-13-2014 @ 2:22 PM |
4ford, I measured the fender on my '41 in 2 places. Just ahead of the running board to the seam measured 18 7/8". and midway from the wheel opening back measured 18 3/8" Hope this is what you want.
4ford | -- 03-15-2014 @ 3:47 PM |
This helps a lot thank you!!!!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7111 |
