ford1941 | -- 03-04-2014 @ 1:25 PM |
My 47 Ford woodie station wagon that I'm restoring has what looks to be two factory original holes for mounting the radio antenna on the passenger side of the cowl. These holes are midway up the cowl and roughly 1" apart (see photo). Does anyone know if this is the correct original mounting location for the antenna on this vehicle? If so, any thoughts on where to find the correct replacement antenna to mount here? I want to ensure I am restoring the car correctly (concourse quality). Thank you!! This message was edited by ford1941 on 3-4-14 @ 1:26 PM
42wagon | -- 03-04-2014 @ 2:48 PM |
According to page A-5 of the 41-48 Ford book the appropriate antenna for your car would mount on the passenger side cowl and although the picture in the book shows the installed antenna,it probably uses the two holes you have in your cowl.
harv | -- 03-04-2014 @ 3:13 PM |
I have the same identical holes on my 47 panel 1/2 ton delivery im restoring. I have the antenna,but dont have a radio. im undecided if i should find an orig radio. let me know if you need a pic of my antenna.
blarge | -- 03-04-2014 @ 6:42 PM |
I have the template that came with the installation kit for the 46 Fords. I will send it to you if you give me your email. blarge@Comcast.net I also have a restored cowl antenna for sale at $300. Bill Large
ford1941 | -- 03-05-2014 @ 6:25 PM |
harv, I would love to see a picture of your antenna if you have one. Thank you.
ford1941 | -- 03-05-2014 @ 6:26 PM |
blarge, email sent. Thank you.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7094 |
