38tudorflatback | -- 01-27-2010 @ 6:11 PM |
Anyone have assembly drawings showing the trunk lid mounting and trunk hinge mounting on a 37 Ford Coupe? If so I could really use them! Thanx. "Hot Rods have a Flathead under the hood and tools in the trunk. Street Rods have a small block under the hood and wax in the trunk." Keep the paint side up!
BillB | -- 01-30-2010 @ 9:32 AM |
Here's a pic...hope it helps
38tudorflatback | -- 01-30-2010 @ 8:34 PM |
Thank You, Nice trunk! The "Original Hinges" that I just bought mount to the car body with "L" shaped brackets inside the trunk. I am sure it is an original car, but think there must have been a wood panel or brace across the back that the hinges brackets mounted to. Does your have that up under the rear ledge? Thanx in advance for anymore help! "Hot Rods have a Flathead under the hood and tools in the trunk. Street Rods have a small block under the hood and wax in the trunk." Keep the paint side up!
trjford8 | -- 01-31-2010 @ 7:50 PM |
On the 37 coupe there are two channel braces that run from the package shelf to the top edge of the trunk opening. The hinges mount to these channel braces. The only wood in a 37 coupe are the thins strips that are in the side panels so you can attach the cardboard trunk panels,
38tudorflatback | -- 02-18-2010 @ 6:45 PM |
Any chance you have a drawing or photo of how the hinges mount? Maybe these are not the correct hinges. Please tell me what you think about the attached picture. Thanx. "Hot Rods have a Flathead under the hood and tools in the trunk. Street Rods have a small block under the hood and wax in the trunk." Keep the paint side up!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=699 |
