EHSON!9$0 | -- 02-03-2014 @ 3:21 PM |
I am restoring a 1951 Ford Convertible but can't find any information on interior lighting. Does anyone have any diagrams, photos and/or stock parts available? Also where are the interior lights located? Unfortunately, my car did not have anything when I got it.
TomO | -- 02-04-2014 @ 2:46 PM |
That information is usually found in the owner's manual. The 51 Ford is being reprinted and is available from most vendors. Here is a link to Bob Drake's site. http://www.bobdrake.com/ItemForm.aspx?Item=DG-167&ReturnURL=/Categories2.aspx?Id=872d0407-bc0f-404d-bde0-2b57bf9a0c1b&Category=872d0407-bc0f-404d-bde0-2b57bf9a0c1b Tom
flathead4rd | -- 02-05-2014 @ 5:50 AM |
Go to the shoebox-central.com web site. Everything you need to know is there. Call the 800 number and Chris the owner will answer your questions.
EHSON!9$0 | -- 02-06-2014 @ 3:24 PM |
Thanks for the help. It appears I will be able to find what I need at shoebox-central.com. What I am referring to are the courtesy lights for a convertible. I have two different brackets that will accomodate a slide switch and a lens that measures 1 1/4 inches in diameter. Also not sure where the brackets were originally located under the dash. Thanks for your help.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6978 |
