ftda1941sd | -- 01-18-2014 @ 3:33 PM |
Does anyone have pics or know what passenger side rear fender brace to use on a 41 business coupe? If one belongs there mine was missing upon arrival. Thanks. Bob
Stroker | -- 01-18-2014 @ 5:27 PM |
Fender braces are symmetrical, check the driver's side and also look for a hole in the passenger side fender where the brace would attach.
ftda1941sd | -- 01-19-2014 @ 6:04 AM |
Thanks Stroker, I'm still confused because parts vendors show different pieces for left and right side. Bob
41-42fordadvisor | -- 01-19-2014 @ 7:58 AM |
Bob in reference to your question about the rear fender braces. The right side rear fender brace panel part number is: 11A-16340-A and is the same from 1941-1948. The left side rear fender brace panel part number is: 11A-16341-A and is a one year only part for the 1941 Fords. As the left rear fender brace panel part number is: 21A-16341-A and is for 1942-48 Fords. This panel looks the same as the 1941 but is wider. The right and left rear panels are of a different size and shape. The 1941 Ford left rear fender brace panel is not being reproduced. Fred Killian
Stroker | -- 01-19-2014 @ 10:46 AM |
Fred: Thanks for giving the correct answer. My head was into earlier stuff. My bad!
ftda1941sd | -- 01-19-2014 @ 11:12 AM |
Thank you gentlemen, I think I got it now. Bob
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6928 |
