Topic: 1935 Steering Column - Paintin associated parts
admiral1960    -- 01-26-2010 @ 8:44 AM
  I am goinfg to paint my 1935 FORDOR DELUXE SEDAN steering column.
According to the 1935-36 Book it should be a "dark non-metallic taupe" as should the lock assembly.
Does anyone know if the clamp at the bottom of the column is painted the same color ?
Does anyone know if the small metal box (case, PN 3712) at the back of the ignition switch is painted ?
Allen E Michler
AW1, USNR (10 yrs)
LTC, TC, USAR (29 yrs)
tbloss    -- 01-26-2010 @ 2:14 PM
  Admiral: The clamp is cadminum plated as is the case on the back of the ignition---no paint. My clamp bolt is cadmium plated, however I have seen a few clamps with raven finish. Someone will know. Hope this helps...Tom..
admiral1960    -- 01-26-2010 @ 4:47 PM
  Thank You.
Time for a little plating
Allen E Michler
AW1, USNR (10 yrs)
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=691
