flathead48 | -- 01-09-2014 @ 4:44 AM |
Once again I need the expertise of our club members. Looking for wiring diagram for signal lights on my 48 car. Using 7 wire switch. Thanks to all , Rick
Drbrown | -- 01-09-2014 @ 8:54 AM |
Not sure the attached is what you're looking for but it is a Southern Cal Speedshop wiring diagram for a seven (7) wire turn-indicator system. I have this unit in my '47 Ford. Otherwise all I have on file is the standard car wiring diagram for a '48 ford V8. Dan
Drbrown | -- 01-09-2014 @ 9:18 AM |
Want to add regarding turn signals .... my turn indicator system was installed by previous owner and the wiring diagram I sent you would be similar EXCEPT he also installed a pair of red colored lamps under the dash edge. Both function to show which side is "blinking" and the right hand one lights when I step on the brake. The integration of these does not show in SO CAL's wiring diagram, but you might be able to figure out how it fits-in to the diagram. Dan This message was edited by Drbrown on 1-9-14 @ 9:20 AM
Drbrown | -- 01-09-2014 @ 9:26 AM |
Attachment N/G in first reply .... here is same in *.pdf format.
flathead48 | -- 01-09-2014 @ 9:47 AM |
Drbrown , perfect thanks a million,
trjford8 | -- 01-09-2014 @ 8:05 PM |
Dash indicator lights are always wired into the front turn signal wires so they do not come on with the brake lights.
flathead48 | -- 01-10-2014 @ 4:15 AM |
trjford8, thanks for the info,
Drbrown | -- 01-28-2014 @ 7:30 PM |
(error) This message was edited by Drbrown on 1-28-14 @ 7:38 PM
Drbrown | -- 01-28-2014 @ 7:32 PM |
(error) This message was edited by Drbrown on 1-28-14 @ 7:39 PM
flathead48 | -- 01-29-2014 @ 4:19 AM |
Drbrown, thanks for the info.
Drbrown | -- 01-29-2014 @ 8:34 AM |
Flathead48 .... there was/is some confusion at my end involving my sending of those two wiring diagrams. Received PM from "Flathead47" (of Ontario) via HAMB Forum asking for them based on a reply/offer I had left in some thread related to him - which I can no longer track-down. And could not include images in a reply to his PM. Regardless, in searching I saw your tag here and didn't notice you are "Flathead48". So there ya go; wasn't really intended for you but if you can use then all the better. Told Flathead47 to private email mme.
flathead48 | -- 01-30-2014 @ 6:55 AM |
Drbrown, I do have it but thanks anyway.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6902 |
