garryfp | -- 12-26-2013 @ 1:19 PM |
I recently purchased a 1934 Ford Deluxe Roadster. I need to change the bulb in the cowl light How do I remove the lens cover. I am afraid of damaging the cover and do not know whether the cover twists off or I use a wedge and pry off the cover Advice is appreciated Thanks Garry
bill t | -- 12-26-2013 @ 4:32 PM |
Garry, Unscrew the oval headed sheet metal screw located on the rear tip of the cowl lite. The rest of the lite will then easily come apart. I have a 33 roadster. Good luck! Bill Taylor
bill t | -- 12-26-2013 @ 4:36 PM |
garryfp | -- 12-26-2013 @ 6:25 PM |
Bill Thanks. Solution seems very simple. I thought that the bolt was holding the inner workings in the cowl case. Garry
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6853 |
